Franco23444
Remember, if anyone else would like to contribute and add more Namco JVS I/O pcbs, please feel free to do so! ![smile :) :)](/styles/default/xenforo/smilies/bb/smile.png)
Yeah, there needs to be one for SEGA and TAITO I/O boards as well but I’m strictly making this thread only for any Namco I/O pcb from any game. I still need to add a few.Great resource you put together brother. I wish there was something like this for the Sega IO boards......that talk about the different pin outs because I have no idea what plugs into them.
I am referring to CN1, CN2, CN7 & CN8.
Photo attached.
Awesome brother thank you so much.
Thank you very much for your quick reply! I will check them in the morning! What type of fuses are these called?Yes, they can in fact blow. There are some tiny components labeled “FL” which mean that they are a fuse. With a multi meter you can check if they are blown, I would check those first before checking the transistors.
hopefully someone can post some high quality pictures of that part here! In the meantime I got some other mystery I/O pcbs I will post here through out the week.Any info on the V180 used in the Cyberlead cabs?
Please do! If you want to upload some high quality pictures that would be a blessing as well! Hopefully we can update this thread with more I/O boards and have it as a helpful tool for anyone out thereI can get some pictures of the cyberlead io, I have a couple. More than likely the CL 1 io. I also have the Marquee io from the cyberlead 2 which is the exact same as the JVS io with things changed between the two. I'll do my best to dig them out for y'all
No problem! I have more pcbs to add but I have been drowning in projects to complete lol! The rays pcb does work on LCDs but there has to be no other source of light hitting directly on the screen or use a matte screen. The Rays camera is a Sony black and white CCD security camera with a IR lens filter.Thanks for putting this together. Didn't know there was a 2nd revision of RAYS pcb.
Had to put heatsinks on H4 chip on my 2nd board. 1st one I had - died without warning.
View: https://www.youtube.com/watch?v=y_w5xeDkx1s
This is what RAYS camera sees and the PCB analyzes.
The laser diode in the gun has a vary narrow wavelength and there is a filter in front of the b/w camera, that allows only this wavelength to pass.
Then the PCB analyzes where is the dot. PCB can turn the LED on/off, so It can run init sequence to check which led is where (2 gun setup).
This setup allows guns to be used without the emitter frame or CRT.
Works with any projection TV or projector.
Does not word well with LCD TVs, because how multilayered screen reflects the laser confuses PCB logics.
While the RAYS pcbs are more “universal”, meaning that they will work with Vampire Night, Time Crisis 3 and Crisis Zone, they do break easily.
Wow! Awesome work!For preservation purposes I have dumped the [JVS] protocol RAYS uses to speak with the main board.
When I didn't have replacement board - my idea was to make a replacement using OpenCV and one of the microPython powered MCUs, capable of running embedded OpenCV.
I got to the stage when the video (with the dot) is correctly analyzed and coordinates extracted, but then I found a replacement PCB and dropped the project.
Had to add inputs and outputs handling and it would be a finished replacement.
View: https://www.youtube.com/watch?v=khpfPEXcfk8
While the RAYS pcbs are more “universal”, meaning that they will work with Vampire Night, Time Crisis 3 and Crisis Zone, they do break easily. The TMIU/MIU/XMIU are far more reliable. They work almost the exact same way, except some games require a specific ROM and PLD chip to work.
Necro thread, but ill try.No problem! I have more pcbs to add but I have been drowning in projects to complete lol! The rays pcb does work on LCDs but there has to be no other source of light hitting directly on the screen or use a matte screen. The Rays camera is a Sony black and white CCD security camera with a IR lens filter.
