Rg111
Multi Boyz
Multi Boyz
USA
Has anyone swapped a G-Net motherboard with a ZN-2 motherboard?
I got a working G-net board with a non working motherboard. I'm hoping it can be replaced with a ZN-2.
I thought the G-Net contained some special customs not on the ZN, likewise hasn't the ZN got a few customs the G-Net is missing?
I'm sure I've tried this once. It didn't work.
To make a GNet main-board run Capcom ZN2 sub-boards you need to salvage some things from the Capcom ZN2 main board: you need to swap the IC353 BIOS, swap the CAT702 security chip, and swap the jumper configuration. There my be other differences.
@penrhos attempted this conversion: Sony ZN-2 PCB - swapping top board problem...
no idea if he was ever successful.
Nope - never managed to get past the blue screen and error code when trying to use a G-net top pcb on a capcom base or a TGM top pcb on a Taito base. both were ZN2 base pcb's.
I did get TGM working on another Capcom ZN2 base board though so that's an option.
