so do the jailbars happen if you seat the kit without a plastic case? I would recommend just reseating the entire multi board and then reseating the entire B board onto the A board. The jailbars are typical of a bad connection between A and B boards. also, is it every game and exactly the same? if so you know that it's not a ROM/Multi issue.I have finally gotten around to putting my multi inside a CPS2 case.
However I am getting jailbars on the graphics when I mount it in the CPS2 case.
The reason for this is removal of the support bar from the case to fit the multi PCB.
Anyone have an idea how I can solve this in the simplest manner ?
Good solution, what do you define as "hard foam" ?Some pcbs will give you fits because the support is gone. I've used hard foam to stcack inside to add support. Whatever you use has to be rigid and not give way when pressed.
