i found the board i have with a 915 chipset. buts its kinda my router. i should be doing a router upgrade soon so will try thenLet me know when you find out the model #!
I didn't do an exhaustive test so far, but seems to work ok with the multis.@deibit: Have you tried the PCI I/O board in a multigame system? I'm wondering what games it's compatible with since the RS485 to RS232 circuitry looks different (simpler) than the regular Taito I/O.That's the PCI I/O
Please don't test all the games on my behalf though, as long as it works OK with the Multi was all the info I was looking for.I didn't do an exhaustive test so far, but seems to work ok with the multis.I'm setting up a new tx2 multi with this main board. I will then test all multi games.and report back.
YJP. It was a lot of 3, and then I had my proxy ask if he had more - ended up with 5 total. 2x1gb of RAM included with each, complete with CPU, fan and even the backplates for the system ports. Cost me 20,000 YEN total (~200USD) from the seller. (Note, that does not include my fees for my proxy or the shipping - and the shipping was kinda a wash since I had some many other items coming in to me).I've never seen a cheap one, where did you score a lot of 5?
Nice score buddy, hope they work outYJP. It was a lot of 3, and then I had my proxy ask if he had more - ended up with 5 total. 2x1gb of RAM included with each, complete with CPU, fan and even the backplates for the system ports. Cost me 20,000 YEN total (~200USD) from the seller. (Note, that does not include my fees for my proxy or the shipping - and the shipping was kinda a wash since I had some many other items coming in to me).I've never seen a cheap one, where did you score a lot of 5?
what a steal!!!YJP. It was a lot of 3, and then I had my proxy ask if he had more - ended up with 5 total. 2x1gb of RAM included with each, complete with CPU, fan and even the backplates for the system ports. Cost me 20,000 YEN total (~200USD) from the seller. (Note, that does not include my fees for my proxy or the shipping - and the shipping was kinda a wash since I had some many other items coming in to me).I've never seen a cheap one, where did you score a lot of 5?
... TEM100-01B mobo is the Type X2 Terminal motherboard (the TTX2 is Taito branded ...
yep, that was the reason I bought these But, by the time I actually get around to it it will be ages. If someone actually makes the kit, keep me in mind!from what I understand, the part the IO connects to is a RS485 to RS232 serial converter. these can be found on eBay for very little.
from what
it has stuff that controls the 640x480 / 720p controls as well as a reset button. How it passes the resolution switch on to the games is unknown, or if it's even needed. If not, this converter is all we'll need.there should be more than just the RS485 to RS232 converter, since the daughter board is also connected to the front panel header...
Also, if you would like to sell one of those motherboards, I'd be a buyer.Headsup, I bought a 5 set lot of TEM100-01B motherboards (complete with cpu and RAM). I can boot up to the multigame menu! I will test it out in an actual cab later tonight.
In any case, the TEM100-01B mobo is the Type X2 Terminal motherboard (the TTX2 is Taito branded - otherwise they both look physically the same exact to me).
Ill report back if it works in the cab. If so, then we have a cheaper alternative when it comes to parts!
