NFGx
Brisbane.au
Excellent condition cabinet with a Nanao MS-9 monitor. SOLD for $2200 AUD
The good:
  • The control panel was completely overhauled. Stripped back to bare metal, rust removed, primed and painted, new overlay, new buttons according to original spec (Seimitsu), fixed up the wiring, and replaced the gummy old covers on the fast-on connectors with new Hirose parts.
  • The monitor was given a rejuve treatment and is laser sharp.
  • The monitor chassis has less than 2 hours use on it since it was refreshed by Jomac. Geometry and convergence are very, very good.
  • Beautifully clean inside, speakers work, beefy original JAMMA harness, plus kick harness.
  • Legit SNK cabinet, with the SNK logo, serial number badge, etc. Keys included. Coin mechanism as well, if that's your jam.
The Not So Good:
  • If you're picky, the monitor might benefit from another rejuve, and it's a bit darker on the edges than the centre.
  • Side art is fading. Some scuffs, scratches.
  • A tiny bit of rust here and there, mostly under the panel and at the very top of the cab, above the marquee.
  • The joysticks (original spec, Seimitsu LS-40) were refreshed, but they're not new like the buttons. P1 down is flaky.
Happy to work with your choice of shipper, if you can't pick it up. Can provide additional photos or details if you want anything I haven't covered here.
Etc: The monitor was blurry af when I got it. When I took it to the technician for a rejuve, I forgot the remote panel, so we couldn't fire it up. When he put the rejuve device on the tube, it showed very good measurements already, but he gave it a quick blast anyway. When I put it back together, the image was markedly improved, and it's crisp af. It blurs out a bit when you crank up the brightness, so I think another blast will make it even better. But it's good the way it is. The monitor's glorious otherwise. No burn, rock solid image.
