BilonFullHDemon
Get and burn some DVDs from the web, I'm sure that will be it
Hi!I got them together. Here is the inside of the dongle. Seems pratically brand new
Yeah its in 246+ mode.you must configure your DVD player in cable select otherwise every other time it will go wrong
Are you in 246+ mode if you have a Namco System 256?
YesYeah its in 246+ mode.
By configure the DVD player you just mean the physical jumper on the back of the DVD drive right?
Okay then yeah I switched it.
Oh I have a fluke myself. I will check the 12v when I got home from work and I picked up a 2032 battery to replace the one on the motherboard.Hi!
Be careful with the cheap multimeter .
20 years ago when I started in the world of Arcade equipment I almost threw 3 CPS2 games in the trash , because of a multimeter coming from a DIY store
The 5 Volt with this cheap multimeter made me believe that I had a good +5V, when not.
The CPS2 had difficulty getting started.
I threw away this multimeter I invested in an Original Fluke
