Hi mitsurugi-w,
yep, progress bar freeze at the first « * »
Just before lunching game, the screen is green, and when I press « enter » on LCD, screen became black and progress bar get stuck.
Your SD card may have failed. This is a symptom.
Try to do a firmware update. Can you post a pic of your setup?
I made a quick video yesterday. I’ll try to upload it here.
My bench setup :
- supergun smallcab
- A board Jap
- B board suicided (no battery) Rev 4B
- SDHC PNY 4gb / SDHC 16GB sandisk
- rom pack : Old and « new »
- 4 wires from multi Dark board to CN pins
Is this a newer kit or the old kit that required soldering?
Does it have a connector for key writing or you have to solder to solder pads on the PCB? Does it have long pins on the main PCB or not?
on the Multi PCB there is:
- pads for Key Writing : i perform solder with a 0,2mm tip and flux
- J17 pin
- J17 pin
I don’t know if it’s a problem but :
- key writing cable is about 30cm
- there is a resistor bridge on CN connector (I don’t take it of)
other information :
- i use à PAL G from save your games with PIN9 bent
- i take of factory strap on the back of B board (from PIN9 of PalG to CN connector)
- i perform capacitor discharge for the 1 and 5 (with a screwdriver during 1 minute)
My suspicion is you have a micro short on one of the ARM pins or one of the small caps near the pads.
