The Spaniard
Coming in the next revision?Maybe both.
I'm blind. Way past my bed time. Will finish this tomorrow.Check the main post. Info is there under supplementary parts.
Might be worth adding the above wording to the first post so people can easily see what the differences are between versions.A few clarifications:
Both editions, standard and advanced, are identical in features barring:
Standard: Through-hole components. THS7316 RGB video circuit.
Advanced: Surface mount components. THS7374 RGBS video circuit. Power LED.
The remainder of features and circuitry is identical between them.
It also looks like the Advanced has the 1k pots and the standard didnt.Might be worth adding the above wording to the first post so people can easily see what the differences are between versions.A few clarifications:
Frank, fantastic project so far. I will let you know how the build goes. I am sure you have lots of feature requests, but i will throw in a simple one. A connector to go out to a gbs8200 and bypass the rgb chip... really just a jst header that i can grab the rgb singles from. For now i will just solder it on at the jamma connector. Well done.I'll keep updating the main post periodically as time permits. There's a lot of ground to cover and I think I've done well thus far.
