How about a pure test bench version?Added some new headings to the main post. There's a future features section now so have a read and contribute any ideas.
Keep in mind things will naturally change, be added, improve etc over time so keep that in mind before committing to ordering PCBs.
All standard DC switching power supplies shall have two separate standard snap and lock connectors (Moles connector or equivalent)
- Output connector will be a 3x3 90-pin snap and lock (keyed); pins 1,2, and 3 are +5 Volts; Pins 4,5,and 6 are ground: Pin 7 is -5 Volts; Pin 8 is +12 Volts Pin 9 is a spare.
- AC impact connector will be a 3-pin snap and lock (keyed) Pin 1 Line; Pin 2 Ground; Pin 3 Neutral
I've used a Waldom Electronics W-HT-1921 crimper for all my molex crimping needs. Probably not the best in the world, but it gets the job done and it's cheap...about 15 bucks.Could you recommend a crimping tool for these Molex terminals? the official one costs ~241€ + taxes and that's way too much just for making one or two miniguns.
I've found Engineer crimping tools decently priced but I'm not familiarized with Molex connectors and I'm not sure if they'll work with this. I have an IC extractor and a wire stripper from this brand and they are pretty good.
About the correct levels in video signal I recommend setting the 1K trimpots as 682Ω in series and 318Ω to ground before power on. This divides the 2.2Vpp signal to 0.7Vpp.
It works nicely with Neo-Geo as is.So how bad would it be to get this working nicely with a neogeo?
perfect! I've got a little bit of everything, lol.It works nicely with Neo-Geo as is.So how bad would it be to get this working nicely with a neogeo?
Single slots anyhow.
Add me to the team. Email: acblunden2@gmail.comCould you hand draw a crude sketch @acblunden2?
I probably won't go down that path myself but since we both use EasyEDA we should add each other to a team and then you can get creating said PCB and I can pop in and assist.
