Fluffy
Germany
Instructions:
This zip file contains two further zip files with the gerber files for the program and character PCBs. You can upload them directly to a PCB manufacturer of your choice, I used https://jlcpcb.com/ , but anyone should work really.
The program board will have 4 layers (a ground and power plane in the centre) and the character board will have 2 layers.
Settings:
- PCB thickness: 1.6mm
- Surface finish: ENIG (this is a chemical gold plating process)
- Gold Fingers: Yes (this adds a process for gold plating slot connectors)
- 30 degree chamfer: Yes (This adds a bevel to the slot connector)
- with jlcpcb you can set "remove order number" to "specify location", which should move the production code under one of the EPROMs.
The remaining settings can be left as a default. I selected a red solder mask to make the PCBs stand out, but any colour works. Colours other than green cost extra.
Some processing costs are per-order and not per-pcb, so ordering more PCBs will amortize those costs. Also keep an eye on shipping and overall costs, depending on where you live packages over a certain amount of money may cost more import duty or taxes.
If you're curious, this is more info than what you'll ever want about manufacturing options:
View: https://youtu.be/mT2Vp3HcIP4
Edit:
Assembly instructions:
https://www.arcade-projects.com/threads/pgm-single-game-pcb-assembly-and-troubleshooting.10015/
3D printed cases:
https://www.arcade-projects.com/threads/3d-printed-replacement-cases-for-carts.10897/
(I like this one: https://www.arcade-projects.com/thr...-and-troubleshooting.10015/page-4#post-176390 )
Labels:
https://www.arcade-projects.com/threads/labels-for-pgm-carts.4930/#post-85691
https://www.arcade-projects.com/threads/cave-pgm-conversion-labels-igs-polygame-master.9562/
  • PGM-PCB.zip
Instructions:
Settings:
There you go. It would be great if a volunteer could try this in case I forgot something.
Thank you!!!!
This is an awesome thing that you have done, thank you very much!
I can confirm that the instructions are great and that with them, I am reaaally tempted to order some even though I already have them... :whistling:
Certainly something you were never required to do, sir.....but everyone is grateful that if you are not in a place to keep up with sales, that you've released the files.
Thank you for the set I've purchased from you years ago, and thank you again for making them public.
I have neither, and my costs (and some new equipment) were covered by sales.
I understand that but, you took your personal time to make this and you agreed to send it to us.
I think we HAVE to thank you
