RGB
Europe
About
Home Arcade System, “HAS” for short, is a device that allows you to play original arcade game PCBs without the need of owning a real arcade cabinet. Think of it as of a game console, only instead of cartridges or discs, you insert arcade game PCBs. As of version 5.0, the HAS is equipped with an OLED screen and an extensive Menu System, which offers a wide array of new possibilities.
General
  • JAMMA, JAMMA+ compatible.
  • OLED screen.
  • Dual Voltmeter to monitor the +5 V and +12 V power rails (1% tolerance).
  • Extensive Menu System.
  • 132 x 80 x 27 mm total size with the plexiglass case (132 x 70 mm PCB size), 156 g.
  • Comes fully assembled (plexiglass case) and with a power supply harness.
Controls
  • DB15 controller ports (NeoGeo compatible, pinout extended to support buttons 5 and 6).
  • Test and Service buttons.
  • Button Test mode to check the device I/O and layout mapping.
  • Programmable Button Layout.
  • Programmable Rapid-Fire (VSync synchronized or asynchronous, 6 different fire rates).
  • 5 profiles per player to save the Button Layout and Rapid-Fire Configuration.
  • 3 Device Profiles to store your settings.
  • 5 Gameplay Modes that significantly change the controls behavior (Default, Tournament, Shmups Arrange, Taps, NeoGeo CP).
  • 5 popular Layout Presets.
  • Ability to combine/merge Button Layouts.
  • Selected buttons can work as ON-OFF switches. Can be applied even to Rapid-Fire enabled buttons.
  • Special functions can be assigned to buttons, for example, you can make the buttons work as Coin, Test, a combination of A+B+C, and more.
  • Programmable Rapid-Fire on joystick directions.
  • 4-WAY joystick restrictor gate emulation.
  • Joystick rotation (90 degrees left/right).
  • You can assign a special function to Player 1 and Player 2 Start buttons when pressed at the same time.
  • The Start button can be used to coin up, either simultaneously, or with a delay.
  • Automatic PICKnMIX trigger.
  • Coin Chute Emulator for buttons assigned to work as Coin.
  • Buttons 1-6 on the JAMMA connector (buttons 4-6 can be disabled), making it a "CHAMMA" compatible output.
  • Buttons 4-6 on the JST-XH 6 pin “kick harness” connector.
Video/Audio
  • All Video and Audio settings can be changed using the Menu System.
  • Fully buffered consumer equipment friendly RGB video output.
  • Brightness regulation.
  • Precise calibration for each additive primary color signal (red, green, blue).
  • Consumer equipment friendly level CSync at 0.35 Vp-p 75 Ohm impedance (can be set to TTL ~5 Vp-p 470 Ohm impedance).
  • Selectable raw JAMMA/unprocessed CSync.
  • Selectable Video Low Pass Filter.
  • Unbalanced audio output, attenuated to line level.
  • Selectable stereo support for the NeoGeo MVS.
  • Selectable speaker +/- swap for Asura Blade, Power Instinct, and various bootleg PCB, like the popular Battle Garegga boot.
  • Video on an 8 pin mini-DIN connector (XRGB mini/NESRGB pinout); audio on a 3.5 mm stereo connector or the 8 pin mini-DIN if the 3.5 mm stereo connector is not in use.
Power
  • Power is delivered through a 6 pin JST-VH power connector (GND, +5 V, +12 V, -5 V).
  • +5V output via a USB-C connector (used mainly to provide power to external HAS adapters). The USB-C can be used to power stereo-modded MVS MV-1B/C or other low-power systems that can operate from a single +5V power supply.
More pictures​
Various accessories were released for the HAS. For availability please visit - https://rgbslab.com/collections/products
Very nice. That's the kind of devices we like to see.
Hi,
I have a Mak Strike V3
Is your "Sega Saturn to JAMMA joypad converter - 30 EUR" compatible with it ?
I mean the buttons mapping of course
Hi,
Pinout-wise it's compatible, but I don't recommend using it with MAK strike. Undamned performed a number of tests and there seems to be a problem with the MAK strike "design". Basically, the controllers (an maybe even the video out, not tested) get +5V at all times, even if the MAK strike switch is in OFF position. In result, when you turn it ON, the PSU creates a huge voltage spike that can damage stuff.. Here's the full research and explanation - http://forums.shoryuken.com/discussion/comment/10326678/#Comment_10326678
The thing though, is that I don't sell these converters separately due to very limited quantity (I've only got a few), they're reserved for HAS buyers. Once I sell all HAS units and I have some Saturn to JAMMA converters left, I can let you know.
Cheers,
RGB
thank you for the feedback
So the mapping is the same, but the connector can be damaged because of Mak Strike V3 model (especially the 5v issue)
Not the connector, but the micro-controller used in joypad converters.
Sounds good to me ;)
Thank you for the details
I've just finished reading the threads
I'll probably buy one of your Superguns soon :)
Please one for me with 1x Saturn and 1xCPS-2 Adapter and 1x "SCART to 2xRCA and 8pin mini DIN adapter", shipping to Germany :)
Could you also provide 8Pin mini-DIN cables to connect the Supergun to the XRGBmini?
Thanks! :)
nice!
would be nice if you did something similar but with the opposite gender jamma connector.
basically a JPAC but improved.
the JPAC has it's good points but its a pain in the ass because it doesn't have an audio amp so you have to use shitty PC speakers or something else bolted on.
Awesome supergun! Have you been able to test the undamned PS3/XBOX360 usb converter with your supergun? I have an XRGB mini, how do you connect the sound to it?
Thanks in advance.
Undamned converter has been tested and works perfectly with HAS. Regarding the XRGB mini - it all depends on your setup. If you want, you can use a direct 1:1 8pin mini DIN cable. Audio will go via the mini DIN cable as long as nothing is connected to the jack connector on HAS.
Thanks in advance.
I've said it before and I'll say it again, these look like a lovely bit of kit :thumbup:
I just wish I had use for a supergun. I'm kinda tempted to get one anyway :D
You mentioned the framemeister, have you had one running though one yet? What are the results like? Do you think it would be ok through a 5m mini-din cable?
Do the kick-harnesses use a JST XHP-8?
Thank you :)
The result with the XRGB mini is positive, I mean, it works just fine. Here's Limpan's setup:
I'm not sure how it's going to work through a 5m long cable, though. One of those Extron RGB devices could be handy if you want to run signals through such long cables.
The connector is JST XHP-6.
All units sold.
Oh shucks...I look forward to pouncing on another run if it happens.
