Hatsune Mike
what's up with the esp ra.de. art on the bezel? Did it come with that? If it came with that, could you take some clear pictures of the stickers?
its art from sellsellsell. itl be hard to take off cuz i used double sided adhesive and never intended it to be removed. it will come off tho. i did the same thing on my egret 2's.what's up with the esp ra.de. art on the bezel? Did it come with that? If it came with that, could you take some clear pictures of the stickers?
Looking pretty good; a little convergence tweaking and you'll be good to goI picked up a couple of proper MS9 yokes (thanks, @ArcSys101 ) and the results speak for themselves. This is with just very quick geometry adjustments.
Thanks so much for your help, @Hatsune Mike
In my case was opossite … China arcade shop owner sent me NAC equiped with A68KJU96X (6F - June 1996) with ms8-29 and he did some moddifications for NAC to use this chassis instead MS9-29… (i have ms9 spare and is time for me to replace MS8 - he start to make me troubles)Beware eBay sellers who hack MS8-29 yokes to plug into MS9-29 chassis and market them as MS9-29 yokes, though (look for the yellow and brown wire pair).
What’s the correct connector to use for vertical and horizontal?If you're replacing a MS8 with a MS9, you need a different connector for vertical.
Looking at the pic posted, I would just replace both sets of connectors. The horizontal connector looks like a China special.
In the MS8 chassis , the cables that comes from yoke looks like this … ive did this to compare to see if the connectors from Ms9 are in the same spotsIf you're replacing a MS8 with a MS9, you need a different connector for vertical.
Thanks!@kikaso can you confirm the size of the knurled thumb nuts you're using for the control panel? I swap panels often on Sega candies and making that job quicker would be awesome.
Great job on the restore btw. This has been very enjoyable to follow.
I’m not picky and I do have those mounts. Thanks for the idea!@kikaso those clips become really brittle over time and eventually snap in half
If you aren't picky, I would use these zip tie mounts and stick the adhesive side somewhere on the heatsinks
Looks great! I did that to one of mine. What a mess haha. I should do my others, too.Very quick update!
Polished the monitor screen and it came out great. The screen looks to have been scuffed up with a Brillo pad or other abrasive material as seen in @imbord3rlin3 excellent candy cab buyer’s guide. The anti-glare coating came off along with the majority of the scratches.
I used cheap polishing pads that attach to a handheld drill and some automotive glass polish I had in the garage. The polish is a fine polish without too much cutting ability. I made about five or six passes alternating horizontal rows and vertical columns. There are still some scratches but they’re not very noticeable.
I would say it turned out really well!
You’re not kidding!What a mess haha
