CPS2 Suicide Free Modchip
I can mate but usually ssf2 nc comes on a rev 3 or 4 board which means no CN9 connector, instead you will have to solder the chip wires to the cn2 connector like someone has done here, i have the same board as you and i soldered header pins on so i could use my cable.
Yeah I'm willing to do whatever to bring the game back from the dead. I'll pm you
So, i recently did this mod, since theres a shortage of infinkey's and my A2 board runs fine. My Alpha board started to work, then stopped randomly. Idk if something burned out or was damaged or what. Ive re solder the IC chip and tried it on a different Mobo and still got the same issue. Has anyone had the happen, or know what else i should check? Im getting a red screen and The board is a rev 7.
So I have downloaded the hex file for xmcotaa to revive a dead Asia COTA.
I have never programmed a PIC with my eetoold TopMax2.
When I import the HEX into the buffer it says loaded and gives me a checksum of BE00h
When I try to program it, it says complete but it reads as all FF
I am sure I am doing something wrong. Do I need to set secure fuses after programming ? I know I am missing something easy, but I have never burned a PIC before.
Any help is appreciated. I made a little socket adapter for the PIC so I dont have to desolder it to reprogram, I just pop it out.
I am used to opening BIN files and burning them to PROMs and Eproms, I have never used a HEX file as source with eeTools Topmax2
Here are the settings I have access to on TopMax2 for this IC:
This may be intended; during the programming process for many ICs, data can be checked after being written but only before the chip is locked. Security is usually at the end of the queue of the programmers tasks. Once locked a PIC will not verify, you'll want to check it in circuit at that point.
I'll try it again, maybe I locked it right away? I will try another one and see what happens.
Thanks!
