Mitsurugi-w
Arcade Admini-Moderator
Staff member
Immortal
New Bern, NC USA
These instructions apply to original pcbs as well. On original sound pcbs the RCA jacks are not installed but can be.
Pin-out of RCA Jacks
Power Pin-out for J1
The factory power connector had pins looped rather than individual wires for each pin:
Speaker Pinout
Connector used for speaker connector on pcb: https://www.digikey.com/en/products/detail/molex/0026481055/26761
Suitable mating connector: https://www.digikey.com/en/products/detail/molex/0009503051/26459
Pins : https://www.digikey.com/en/products/detail/molex/0008500106/26477
Connector used for power connector on pcb: https://www.digikey.com/en/products/detail/molex/0026481075/26765
Suitable mating connector: https://www.digikey.com/en/products/detail/molex/0009503071/26463
Pins: https://www.digikey.com/en/products/detail/molex/0008500106/26477
Are the connectors molex?
Looks like the post was updated. Thanks!
Looks awesome thanks for the info. Whats included with the sound board?
I already made a fingerboard adapter to power the soundboard, just need to know what connector, pins, crimper to use to make my custom harness/adapter.
Are you planning to sell a few of these @Derick2k ?
Ok, slight update, but Im getting close to ordering what should be the final version of this. I hate feature creep :D
Still have to tweak the layout a bit, double-check spacing, and probably rename a couple of things but here we go:
  • We have 12v fan headers
  • power and speaker-level audio connectors that go to the Batman sound PCB
  • 3x4 2.54mm pin headers, these are used to switch jamma audio from the STV MB or the Batman sound PCB, unfortunately, I could not find a 4PDT switch to fit the specs needed (size, contact rating, etc.)
  • We have the button remap slider switches
  • Finally added an LED voltmeter (this is optional)
This will be a 4-layer PCB with 2oz copper and gold enig - it will probably be black color. I have spaced the jamma edge according to Hirose's dimensions.
Let me know what you guys think. Any changes or suggestions?
It has everything I could possibly ask for. I'm really excited to see an stv kit properly tied together!
Awesome! The button remap too
This is going to make a complete streamed line kit
Quick question for you guys, will you all be using Everten's Line out/Kick harness addon?
Also, I need to remap P1 & P2 buttons 4 from the kick harness.
Do you guys want time to swap just button 4 to button 1
or remap all the buttons? meaning
From
1-2-3-4
to
4-2-3-1
or
2-3-4-1
For me, that's a yes on Evertens board. I don't really have a preference on the button remapping.
Same here. Using the Everten board.
yes on everten - maybe i missed the post on the remap - why do we need to remap the buttons?
On Batman Forever JAMMA button 1 is not used and the 3 buttons that the game DOES use are mapped to JAMMA buttons 2, 3, and 4, so you essentially have to shift them all over by 1 on the JAMMA edge.
It's documented on pages 23 and 24 of the manual: https://www.arcade-museum.com/manuals-videogames/B/BatmanForever.man.pdf
I ran the game at a party last weekend and made a hand-soldered JAMMA pass-through to play the game that shifts the buttons over by 1 and provides power to the audio board.
I'm not really sure why the kick harness needs to be involved though.
I'm curious what game would need button 4 coming in from the kick harness as part of the remap
Long night ||
Was looking at the STV manual pinout lol
Still bizarre that they did this:
So the only thing to decide is:
From
A-B-C-D
to
D-B-C-A
or
B-C-D-A
Simplest would be to slide the D to the A
But I think it should be to move buttons over 1 spot so
B-C-D-A
