512, waiting to find cheap 2x2GB...How much Ram working in your TTX2 ?Received the Intel Core 2 Quad Q6600, working fine !
that's definitely not normal.. fan must be always on when the power is on.Today i found out that the fan of my 7900 GS graphics card in my TTX2 not always starts.Is that normal ? and has someone the same Problem?
Can you post a pic ?oops, then I stand corrected My main 7900GS fan (Zalman) is not connected to the the Graphic Card, but to the one mainboard fan header (and this is always running). I thought it was the same for the OEM fan.
What are the 2 red pins at the rightt? a standard Q965 header is one row shorter:Ok, So this is what the front panel header of the motherboard looks like. The 3 pins marked in red have to be connected to the JVS card or you will get an I/O error. Fortunately they have nothing to do with the lights, or buttons so you dont need to tap into them or anything. I just used a male to female jumper wire like you would use with a breadboard.
What do you mean This multi will not work on a normal PC.Hi and welcome yotsubalim.
This multi requires a Tatio Type X2 setup to use.
If you have one then all you will need is a 60+ GB HDD/SSD to install it on to. you will need o use the whole drive for it as it includes the OS as well as the files to launch your games.
Games are not including in the download links provided on this site.
Edit: This multi will not work on a normal PC.
the multi is only for the original arcade hardware Taito Type X2.
if you want to play Tatio type x games on your pc there is downloads available around the internet. But due to the rules of this forum i cant give you any direct links.
googling TTX2 dumps should yield some results for you
can you please pm me the link please im already search for this last 2 year no luck found T.T
Fixed your quote for you, and @corey, don't hook this dude up. I'm not normally a rude guy, but if he's not willing to get the HW and play the games the way that is discussed in this thread, then he can hit google and research on his own.can you please pm me the link please im already search for this last 2 year no luck found T.Tthe multi is only for the original arcade hardware Taito Type X2.
