This update is available and it has the kunimitsu update
Anyone got this?
I have the update usb for that version but it doesn't work unless I get the new round 2 dongle. I've been trying to get my machines on that version for 2 years. Good luck getting an image that works with the Namco ES3 for round 2!! I know it's out there, someone has it I hope ....
What's the meaning of "TGE" ?
This version works on PC but i didn't see any public dump (reminder: this is piracy if you don't own a license).
This also works on real ES3, with offline mode just like your pictures. You still need 2 ES3 to link them and play versus.
First make sure you have a separate router for only Tekken 7, then make sure the router settings are the same as the picture. Next plug in both lan cables from each tekken pcb to the router I use linksys. If both pcbs aren't the same game version it wont work. Label the first pcb RED group A the second has to be BLUE group A. I have got 2 linked and 4 linked so I know it works when you are in the room pick the option below cpu it really doesn't matter both options should connect to each other, try it!
thx for the heads up
linksys router model?? also how do i enter router settings on router??
I just discovered something really awesome!!
So this worked for me on a taito type x2 for Street Fighter 4 and I hope it also works for Tekken 7 or any other game that can be connected to a virtual network like hamachi.
First you have to have the same version of the game or it will not work!!
Hamachi online play,
Host (Master): install hamachi, create a network.
Client (Slave) install Hamachi and join the network someone created.
In the Test menu, access the system options menu:
Whoever creates the game does not need to choose this option, only who enters.
Exit the test menu, 1P starts the game and right after, 2P you can enter the game.
I tested with someone else and gives low lag but I saw that there are tutorials to improve the performance of hamachi. Anyone want to try this for Tekken 7? Or any arcade linkable!!
will this work for taito x3 st fighter V?
From a pc or laptop Plug a lan cable into the router on any numbered port and type in the ip address for the router user name and password are default admin - so user name is admin and password is also admin
New 4.20 Dongle!!
This could be done I think, it's very close to the version dumped and already used in it.
Anyway, I don't think that the kind of discussion we want to have here.
