9999 Damage
Short version
My System 16B is showing a black screen after a motherboard recap. The power LEDs come on.
Background
Emboldened by successfully recapping a few arcade PCBs and consoles, I thought I should do a preventative recap on my System 16B before installing it in a Semload case. A few of the through-holes had stubborn solder trapped inside, and I lightly burned the PCB around a couple holes. I didn't notice any lifted pads, but it's very possible I lifted some pads after applying too much heat.
When I powered it on with an installed 16B Multi, I was able to play fine initially, but Shinobi froze after about 20 seconds. After that, I could switch games, but it would freeze until I put light rotary pressure (!) on the Deluxe Selector's dial. Seriously, I could pause the Golden Axe title screen by releasing pressure, then resume by restoring pressure. But after I played with that for a minute to understand what was happening, I got a black screen, and couldn't get it to recover after power cycling. I tried swapping in my old Bay Route ROM board conversion, but I still get a black screen.
Troubleshooting
Background
Troubleshooting
- What should I do next? Presumably one or more caps isn't installed correctly, maybe because there's a lifted pad and it's not actually in-circuit. Is there a way to test each cap to confirm it's installed correctly? Or does the black screen confirm the board is already damaged in a way that will require troubleshooting (and repair, if possible) by someone who actually knows what they're doing?
- I recall replacing either the Z80 or 68000 as part of the multi install. Is there any reason why the non encrypted Z80 or 68000 wouldn't work with a Bay Route ROM board conversion?
