kinooshi823
Yeah I asked him to shoot me pics so hopefully I get em sooncall him and ask him to send you pictures of his cabinet: the wiring, the IO, everything ... post 'em here!
I messaged him to see if he can send me more pics of that area.So i see:
a jvs to jamma
a vga to hdmi
and the jvs card with an additional thing plugged it in (the blue connector)? What is that? Is that the jvs to jamma? I dont own these so not certain. Can he go in test mode and run the jvs input test? Does it work?
The rest is pretty standard, like my american naomi universal, which can run the lindbergh fine here :
He said the blue cable is not connected to anything. For video he is using a male vga from the lindbergh to usb connection.That IO that he's running is a Sega Type 1.5, which is indeed a Lindbergh IO.
However he's got the JVS output on the IO populated (The blue cable that MrHide pointed out), so does he have a Versus link board in this cab? Secondary links in the JVS chain could cause an issue I'd recommend unplugging that.
I also have no idea how he's powering the Lindbergh from that NAOMI PSU, none of the pictures show that connection and it shouldn't be compatible.
He also says he uses the blue cable that gets connected to a dynamic golf control panel for trackball support but it was not connected at the time he had the issues.
I looked up the manual for the net city and for video is dsub to dsub am I right? so that would mean if he's using a vga to usb there has to be some kind of device connected that isn't part of the net city in order to get picture right?ah! the lucky dog that is really the only valid thing to put there. Good.
vga to usb? uh?
@Mrhide I made an error, so the pic he sent me I thought it was a vga to usb but he was infact holding 2 separate cables. So he is getting video vga to vga and the usb cord would be to his JVS card on the Lindbergh
he replaced the JVS card before sending it out to me and said he got the same issue lol. All I can do is redo everything from my end and retest and send it back. Although it was working fine. I can't do anything if I don't have his cab in my possession
So I redid everything like I said and then, I remembered I have a vga to bnc connector and I used that to hook the lindbergh to my pvm. Although there is a sync issue with a double screen effect. I could still see it boot to the menu. And what do you know? no strings errors, no nothing. So that means it has to be an I/O issues on his part but its certainly something in his cab that is causing the issue. I did what I could and managing to get a picture here on my crt and see no errors pretty much sums it up.I like the way you think.
So my friend messaged me yesterday as he got around to trying the unit out.Isn’t there an Xbox controller ver of outrun for Crt on the game select ..
As that uses an Xbox controller and displays in Crt mode ? ( no I/o required )
Can he test with that game and
See if he gets a picture ?
I have had same issue as this ..
And this has been enlightening for me ..
I get a no sound card error on outrun
Vf5 runs ok for me
& Too spicy
