If you send money to Mark you have maybe a 60% chance of actually receiving an item. And if you do, and it doesn't work, he'll just tell you repeatedly that you must be using it wrong and refuse to either tell you how to use it correctly, or admit that maybe its broken and fix the problem.
Wow good to know. This guy is local to me, I've stumbled onto that site a few times but never purchased. Guess I will avoid it!If you send money to Mark you have maybe a 60% chance of actually receiving an item. And if you do, and it doesn't work, he'll just tell you repeatedly that you must be using it wrong and refuse to either tell you how to use it correctly, or admit that maybe its broken and fix the problem.
That would explain it. Is the slim video connector backwards from the phat pinout also?As Mitsu likely encountered though, the video pinouts shown in documentation are backwards.
I don't recall, but I am inclined to say 'yes.' I remember when I first hooked up my SLIM using the documented pinouts, the video was all scrambled. Reversed the plug on the video connector and it became apparent the documented info was incorrect. Then when it came time to do the PHAT conversion to JAMMA, I seem to recall doing the connector the same as the SLIM and then finding it was incorrect (reverse RGB, but same Sync and GND positions IIRC).That would explain it. Is the slim video connector backwards from the phat pinout also?As Mitsu likely encountered though, the video pinouts shown in documentation are backwards.
