emmanu888
Victoriaville, Quebec
Do i have to split the VGA output and splice in audio or is the DVI output also active and mirroring what's on the VGA output meaning it could be converted to HDMI using an adaptor that can have the Lindbergh sound output injected through?
EDIT: don't mind me. Am easily confused. See below for a better answer!
The DVI connector on the Lindbergh is an output and for the majority of games does mirror what the VGA is outputting, so yes you cold combine the DVI and the audio from the RCA to one single HDMI feed if that's what your capture card takes.
  • Like
Reactions: nem
