Mitsurugi-w
Arcade Admini-Moderator
New Bern, NC USA
The "Bottomer"
Price: $25
This version allows you to simply place the dips on the bottom of the pcb where they can be more easily accessed for multi use. SOLDERING REQUIRED.
Remote Dip PCB with 3 Foot Flat Cable
Price: $45
This version allows you to extend your dipstwitches up to three feet from your multi pcb!! SOLDERING REQUIRED.
Filterboard Mounted Dipswitches
Price: $45
Comes with your choice of 20cm, 25cm, or 40cm ribbon cable. Specify when ordering.
This version allows you to mount your dips directly on the filterboard of your CPS1.5 multi. It uses a sleek design and mini dipswitches to fit snuggle onto the filterboard without being obstructive. With a longer ribbon cable could be mounted elsewhere on a custom case. Professionally manufactured. SOLDERING REQUIRED.
I'll take 3x of these:
Price: $45
Ill send $145 to your Paypal which should cover shipping as well, correct? :)
Hi,
I would like to take a "Remote Dip PCB with 3 Foot Flat Cable", I'll send you a PM.
They have arrived!
Will begin shipping remaining pre-orders tomorrow!
As a side note I ordered various different lengths of ribbon cables to test. A longer cable allows you to mount these other places than the filterboard. Perhaps somewhere on a custom case?
This uses mini dips so you most likely need a pointy object to help flip the switches. I actually want to challenge someone to design a holster for this so you can pick it up to more easily change the dips.
Also you want to remove the plastic film before using because these dips come in the on position and you need to swap them to off for most dips.
No screw holes to mount to anything :unsure:
Double sided tape isn't pro dawg. *fingerwag*
The original remote DIP (while big/bigger) is the winner for custom cases.
YES its important to crown a winner because we can't have 10x different cases designs all supporting different hardware options.
Standards are a thing for a reason, we can't reasonably progress without them.
Got my kits today. Everything works great!
