When reporting issues, could you all please put what setup you're using as this will ultimately help if there are issues.
What A-Board?
What C-Board?
Also any other info unique to your setup, such as the size/brand SD card.
If there's graphical issues, etc. if you have the patience, you could try formatting the card and putting your games back on, or even better try another SD card.
If you want to go the extra length, and have another A or C board, please try the multi with those (don't forget to remove the multi from the A-Board before installing another C-Board otherwise it will flex too much.
Please make sure you've done the basic troubleshooting, such as making sure the stack is tight, all connectors are in place, voltages are right, etc. too
What A-Board?
What C-Board?
