Mitsurugi-w
Arcade Admini-Moderator
New Bern, NC USA
CPS1.5 Multi Spinner PCB
Price: $55
This adapter allows you to use various spinners to play Forgotten Worlds on your multi as intended by simply plugging into the proper connector on the multi. It allows two spinners to connect via the 8-pin connector. Depending on your spinners design you may need a wiring adapter (not included). This will work with the Hursit Spinner reproductions as well.
4 ft Cable Set for Spinners
PRICE: $35
This cable is for use with the multi Spinner pcb. It includes connections for two spinners. Hursit spinners are supported by default but I can adapt it for other spinners.
Can we connect up the spinner PCB and just leave it?
Or will leaving it connected negatively affect other (not Forgotten Worlds) games?
Hi. PM sent for the following
Could I have 2 x spinner adapters
And 1x dip swtich remote board.
Let me know to pay.
Many thanks Justin
PM sent, but... any documentation (which spinners work or are preferred, etc) so I can start shopping for the rest of the build?
Let me know to pay.
Many thanks Justin
Send me a PM if you haven't already.
How easy is this bad boy to take off and put on the cps2? Should I order a second one for that?
