I am curious about this too , how is the Power Supply mounted ?
The power supply was mounted in the most difficult possible way unfortunately. I unscrewed the wood board and mounted the power supply with screws up from the bottom, then reinstalled the wood board. I was hoping someone would eventually make a 3D printed mount that the power supply could snap into. Maybe if I get a 3D printer I will cobble something together.
Thanks for the heads up , it looks clean .
Tried to get a couple of these but didn't get a response so I went off and ordered the parts. Here's a dump of the information that I gathered while doing this, hopefully it is useful to someone.
https://github.com/wifiber/AWSD-PS-Interface - Github link which is really everything you need. Take a look at the readme.md file. It contains links to the V5 board and presumably any future updates as well. 3 of the boards are $26.
Actual part numbers from the parts.txt file for the connectors -
LCD Voltage Readout
https://www.aliexpress.com/i/32840259666.html?spm=2114.12057483.0.0.206f62fepYHKGu
J1 - Molex MiniFit JR 2x4 0039290083 (gold) 0039281083 (tin)
J3 - Molex MiniFit JR 2x6 0039290123 (gold) 0039281123 (tin)
J4 - JST B5P-VH-FB-B(LF)(SN)
SW1 - C&K OS102011MA1QN1
https://github.com/wifiber/AWSD-PS-Interface/blob/master/parts.txt
Mouser link for the 8 pin connector (2x4)
https://www.mouser.com/ProductDetail/Molex/39-28-1083?qs=orQbfqMgxgWE1Pu2XYbwgg==
Mouser link for the 12 pin connector (2x6)
https://www.mouser.com/ProductDetail/Molex/39-28-1123?qs=EaMIwIL37xzCyl5w6av%2BuA==
Mouser link for the C&K switch
https://www.mouser.com/ProductDetail/CK/OS102011MA1QN1?qs=WtljUlYws5R6MUgHcLkz4w==
JST / GAM-GEC.com link for the JST connector
https://gam-gec.com/product/bh5p-vh-1/
I skipped the LCD readout.
Sorry about that, I saw you reached out and should have responded. My bench is not really accessible at the moment, so I am pausing on building these for a bit. Looks like you were able to source the parts so hopefully you got all setup. I think @Lemony Vengeance did a batch as well, so that might be another option.
  • Like
Reactions: Rix
I have a bunch that will be ready once the voltmeters get here :)
Did a quick and easy mount using the stock Wei-Ya bracket. I flipped it around so I could adjust the voltage pots from the left side.
Use M4X5mm or 6mm screws so you don’t hit the bottom of the power supply pcb inside.
The data sheet for the Mean Well QP-150-3A shows optional mounting feet. Searching around, it looks like the part number is MHS012.
I ended getting these feet. The good news is they’re very cheap. The not so good is that they’re meant to be installed with the power supply in horizontal position… I didn’t realize this until I got them 😅
I ended just bending them so the feet themselves were flat instead of L-shaped. Here’s the results when installed.
4AAFBC07-0BB6-48BE-A614-777014A3B3DD.jpeg26206B61-07F3-435E-89AA-7B170E4C4DFC.jpeg6F7869D5-C5DB-47D6-9713-FCCEA0A6EA60.jpeg
BTW, the interface works like a charm! Great job!!
Fans arrived, did a little more cutting on the case to removed the internal/lame-airflow restricting grill.
Hi everyone!
Sorry to derail this thread, but would you know if there is any chance I can internally swap out the fan for a ‎GELID SILENT 6 FN-SX06-38 ?
thanks a lot for any pointers :)
Edit : tested, and too thick to fit inside as is.
Wondering if someone can help me real quick,
I tried to install the voltage meter and switch on the pcb. When i power on i get 0.00 reading.
Not sure if i wire it wrong or maybe i have to solder in Jp2 and Jp3 in the back?
