hardyhell
Thanks. So I unplug the yoke and measure wich pairs? I see 4 values in these lists.
Lh lv rh rv how can I find out which is the right one?
Thanks.
Thanks.
LH -> Inductance in horizontal coilThanks. So I unplug the yoke and measure wich pairs? I see 4 values in these lists.
Thanks.
Chassis/Monitor | Lh (mH) | Lv (mH) | Rh (ohm) | Rv (ohm |
Nanao MS9-29 | 0.33 | 14.00 |
it is a hell of work to get the picture right then? with the yoke added to another tube? did that with a naomi monitor one time. never got it back goodI would try swapping a MS9 yoke on the Tosh tube that you found.
Lol ! Tell us how you really feel about Zenith?!Yeah, you should be able to swap them. Neck connector and heater voltage match, so it should fire up.
However, you're trading a Hitachi manufactured tube for a Zenith.
Is there anything else wrong with the tube apart from the scratches? You do know you can sand and buff the glass?
https://www.arcade-projects.com/threads/polishing-a-scratched-monitor.11302/
Is it necessary to replace yoke?
Сan anyone tell me what is the value of the original crt tube?
