wLaunchELF MECHAEmu: Access your COH-H10020 security dongles from retail hardware!
Since the chat about this arised, please system 256 owners: remember that due to the system 256 recycling the PlayStation X memory card port board, but keeping it a little bit "deeper" inside the case, some of these cards may not fit bc they're thicker on the display area.
Fortunately, bitfux is releasing their on version of the SD2PSX, without this issue
This is a awesome development for sure and something i would like to play with.
Cause to date i can use a sd2psx as a dongle, have wlaunchelf on 2x6 to boot as a screenless option (thanks krHACKen and others) and write 2x6 dongles from pc using the ps3 adapter.
But to do it from a retail console would be refreshingly new. Great job.
KELF encryption seems to be working!!!
Everything seems to be ready for release. Will test out some stuff and prepare the release, the following software will be included in this release
  • wLaunchELF 4.43x_isr_coh (file browser for arcade)
  • wLaunchELF 4.43x_isr_mechaemu (browse dongles on retail PS2)
  • DongleBinder (bind an arcade KELF to the dongle, to be used as boot.bin (currently: only from retail PS2))
As well as
  • Instructions on how to use kelftool appropriately to convert an ELF into arcade KELF
  • Something more...
everything seems to be ready!
Any moderator can tell me if it would be better to make individual threads for both wLaunchELF 4.43x_isr_mechaemu and donglebinder? or one thread for everything?
Hey I tried the wlaunchELF from the first screen on my ps2 but it keeps booting to a black page. I renamed to BOOT and placed in the boot folder.
Hit the select button when you get a black screen. If it goes to configuration screen that likely means that you have a config file for wlaunchELF on that card
Hello, Guru!
Is there any tutorial for noob like me to backup & restore dongle for system 2x6?
Thanks.
Hello, Guru!
Thanks.
Grab a SD2PSX or PSXMemcardGen2 and load it with the files ( https://www.arcade-projects.com/thr...a12-for-use-with-sd2psx-psxmemcardgen2.32720/ ) that I put in the pre-built in the 246/256 section of the forum, it's probably the best way to do this at this point.
TO USE A REAL DONGLE
1. download https://archive.org/download/bound-sd-2-psx-by-name.-7z/UnBound.7z
2.Extract the files of the dongle you want using isobuster to a flash drive
3. Load the special version of wle in this thread
4. Copy extracted dongle files to the dongle of your choice
5. Use donglebinder to bind boot.bin to the dongle or device of you choice
6. Use it
