MetalliC
have you tried without -ata switch ?We got a new ide to USB adapter and while we have a different ATA id, between pingu and rockman they still come up identical.
How do I do the hex dump?
Without the ata switch it defaults to thinking the device is scsihave you tried without -ata switch ?
I tried the one you linked to with -x but got the same results.Try the new version with the -x command ? Then you will get the Information Section with some details.
No need to enable SMART for the cards.
I came across this post of yours elsewhere. I have 6 boards with the ymz770 on it that im more than happy to set for sacrifice.Try the new version with the -x command ? Then you will get the Information Section with some details.
