gamescollector
- Joined
- Jul 21, 2015
- Messages
- 61
- Reaction score
- 29
Hi Guys unfortunatly recently i have a problem with my lovely original Taito Ninja Warriors pcb, when boot it in the center monitor show COLOR RAM ERROR. (not show in monitor Left or right)
checking online I saw that these Taito cards often suffer from Toshiba RAM failures specifically the TMM2063P 8kx8 SRAM DIP28
I understand that I will have to replace one or two rams. The important thing for me is to identify the faulty ram without starting to randomly unsolder the 6 rams. I hypothesized that the faulty rams could be the central ones if the layout of the 3 ram rgb zone monitors is linear.
Online I found some adapters to be able to socket the rams from component side, and obviously I have to use a tester (at the moment I have the TL866II plus) that I have to understand if it can test them.
Does anyone have experience testing RAM by directly soldering it to the PCB?
I ask for help from you repair gurus
thanks in advance
thanks in advance
