So you have two plugs to the wall? one for the 4 way extension and one from the cab for lights etc?
or did you wire that into the line filter, either way it looks pretty tidy inside.
I really want to find someone of those 1P 2P stickers :D
To make it easier for you I've taken a few pictures tonight the cab was chassis mount stepdown converted by the previous owner, the line filter had screw terminals so no wiring was cut.
Also as I don't like marquee holders I've added a cover made from a sheet of magnetic plastic to cover the hole at the back & keep out dirt ect I'm also missing a monitor cover cap.
After the full strip down & clean I made some more progress tonight by reassembling the CP area as I took it to work & gave it the rattle can which worked out ok.
I also had my first power on, that 100v fan at the back was disconnected straight away :D I think the fans on the lcd are good enough for home use
1L6B CP may be temporary thing, I have a Lindy 2L 12B OEM UK one but need to remove something on the cp surround first.
This might be a stupid question..
I wasn't quite sure what to do with my Lindbergh universal, but i'm liking the idea of putting a lindbergh multi in there mainly for VF5 FS and Virtual Tennis 3.
My Lindy has a 1080p monitor swap already done, lindbergh hardware is 720p only I think, so i'm assuming it would work fine if the monitor supports 720p?
Hmm, so i'd need to check whatever LG monitor i'm rocking in the cab can support 1280 x 768 and ideally 1360 x 768. I'm guessing it can becuase it supports 1080p :D
Have you considered a TTX3 Artax setup? Might be better bang for buck.
I have VT3 on a Ringedge, that plays up to 1080 and looks great on my Noir.
Or just use any pc with that image & a JVS-PAC 2 I put some code in the pac thread so you can just put that on a sd card & have the image default controls in a instant just like how it on JVS or Fast I/O.
I have the community image 1.3 which has some newer arcade titles such as VF5, DOA6 & Rolling Gunner.
I'm keeping my Noir as a dedicated 1p Pi set-up as there are some fantastic images around these days using a JVS-PAC 2 again for controls.
Arcade Punks has a great selection of Pi images that still work great on the Pi 3B+ which should be cheap now.
Regarding cleaning: Brasso works wonders on scratched/marked plastic too I used a little last night on the bezel & was pleasantly surprised makes a cheaper alternative to using Novus & handy as most will have it at home.
Here is my Pi set-up I've put it side ways so I can easily access the sd card slot through the pcb tray handle slot & swap out images.
It is I have a little heater (450watt) now too, I took the mini Astro to work as I thought it would look better on my desk.
I thought about going all foil top to toe but thought it might look like a "grow" tent :S
35-40 Fahrenheit here in the evenings during winter, so we don't know what cold actually is. We might see snow once every 30 years for 5 mins. I hate warm climates but this is about as cold as I want to be. Not tough enough for real winter States.
Colder than I thought prob quite dry though because I live on a Island the air is always quite damp in the winter.
Along with my foil order I grabbed another Lindy instruction space insert which is better than looking though clear glass.
I also found lock space filler thingys from work from a scrap ipub fruit's as I don't need a lock on the middle door for home use, grabbed a few spare too.
