When I first started I found quite a few of my errors were just the 1.27mm socket pins on the dumper board needing to be resoldered. Can't hurt to try.I thought it was the daughterboard's fault because the cart was working before I desoldered everything
Just resoldered everything again - the programmer side was just used to program a C ROM that verified fine so should be ok
MD5 verification failed upon dumping the V ROM I just programmed. Going to run the PROG command again I guess
Hmm.. I need to look into it again. I recall seeing the connector on only 1 side. I'll look at it next time I make one of these carts..I've cut into a couple of mine by accident while cutting down to size and mine are definitely dual wipe
My guess is that if you use a memory card (or a solution like the Neo save masta) you'll be able to get around this limitation. Not sure if all MVS games support the memory card however......This cart will not be good for anyone that cares about high scores. Some people are pretty concerned with high scores, so this is good to know.
I have this solution also - it is like a SaveMasta:My guess is that if you use a memory card (or a solution like the Neo save masta) you'll be able to get around this limitation. Not sure if all MVS games support the memory card however.
I do use neobiosmastaVMC on most of my MVS PCBs. Turf Masters supports memory card, so I should be good.My guess is that if you use a memory card (or a solution like the Neo save masta) you'll be able to get around this limitation. Not sure if all MVS games support the memory card however.
That looks pretty cool. Where did you get it?I have this solution also - it is like a SaveMasta:
You Can ping me here: https://twitter.com/NeoJammaThat looks pretty cool. Where did you get it?
I'm always interested in this stuff.
Interesting, this can't be shipped to CA. Figured for $9 I'd pick one up in case.
If the Usb Blaster dont supply the correct voltage, could be connect the vcc/gnd pins to a external power supply, per example a arduino with 3.3 V out? or the boar must be connected to a mvs board (mv-1, etc...), the mvs or aes card could be connect to another power supply (Power adapter) to the cart pins?I had one CPLD that refused to be programmed by the programmer I suggested and had to use a USB blaster on it.
The USB blaster will not supply power to the CPLD/board. The VCC/GND pins on it are just used as a voltage reference. What you will want to do is hook up the USB blaster to the jtag port, then have the board plugged into and powered by an mvs motherboard. I also had a bit of a headache getting it working, as it turned out the clone I had was bad. Took a while to figure out that was the problem and not something I was doing wrong.
This was the bad one
https://www.amazon.com/gp/product/B00CAVG4JS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This one worked
https://www.amazon.com/gp/product/B07F5H5LPZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
