Sorry for the Necrobump here, but I have a question on adding a couple of RCA cables to the sound board. I followed the
CAGE sheet instructions on page 2 here, which says if you are gonna go straight from the sound board instead of the JAMMA edge, and you are foregoing the subwoofer, that you should connect lines to pins 6 and 11, as well as 9 and 10 so it will supplement the standard stereo with a bit more oomf from the bass signal. I opted to not use a sub because the cab I'm putting the board into is an old gutted Arcade1Up (
just a fun mod I wanted to do) and there's not really a huge amount of space in there what with the PR board (even without its rage cage), the PSU, wiring, etc etc. So I opted for just stereo speakers.
I wired some RCA jacks to the required solder points (underneath the pins on the sound board and ran them into a small Kinter powered amp. I noticed the sound was lopsided, good sound from one speaker, and veeeerrry faint sound from the other. So when I went to disconnect to troubleshoot, I noticed the RCA cables were pretty damn hot. Not burn-your-hand hot, but pretty damn warm. Also the heat sink on the sound board was quite warm as well.
So I disconnected my soldered wires (they were solid connections from what I could ascertain) and just went monaural for now until I can figure this out. With mono sound the heatsink is cool as a cucumber. Did this happen to anyone else?
