plasticfactory
Hello, I'm having audio issues with a PR board, that appears to be related to a short somewhere. I'm looking for schematics as following traces for hours has so far been fruitless.
It may not exist, the image attached is all I can find. T-Mek uses the same board I believe, but I am running into the same issues there.
Essentially, I have no audio. The CPU passes its test (LED is lit as well), and ROM Checksums are good. I could push on the DIN 96 connector (ROM expansion connector in the image) and get sound, so I reflowed that part but now I can't manipulate things to get audio at all (though the DIN no longer wiggles). I've ordered a replacement, but doubt it will actually fix the problem. The board itself looks great, and I can't find any faults or damage anywhere.
EDIT: Sometimes I can get audio by wiggling on the DIN that connects the sound board to the main board. Though I'm not getting audio now, and this isn't working, it seems the problem is clearly with this connector.
It is press fit, and I have OEM replacements. Does anyone have any experience replacing press-fit connectors?
