BigSchmid
Seattle-ish
If I'm looking to put a TTX3 unit inside a Noir and use the JVS port on the TTX3 for my IO, what sort of IO do I need to get? The Jamma edged Sega IO won't work right? Thoughts?
The Noir has its own I/O, are you saying the TTX3 doesn’t recognize it?
X3 is fast io is it not? If that's the case then the noir io won't work
Yeah, but it's possible to use a JVS IO as well, but that aside. Lets say you have a NAOMI setup, you can just plug the USB cable from the NAOMI straight into the NOIR IO board... that's correct right?
Correct, the Noir has its own I/O board that you can plug a JVS system into, like a Naomi for instance.
Thoughts?
Blasphemy
Thanks for confirming this!
just to clarify, the Noir has the JVS I/O at the back behind the centre panel and where you would put your 357/naomi/TX3 in in the front there is an intermediate board which you plug into (JVS, video and audio) this then links to the actual I/O, monitor and amplifier.
Picture of the 'intermediate' or STD CONNECT board.
