codecrank
300wins gave me a reason to finally learn how to make PCBs :) Get a drop in replacement that have buttons for the extra service menus ( Geometry , RGB settings )
All the info needed to modify the existing board
https://wiki.arcadeotaku.com/w/Toshiba_PF_D29C051
Here's a comparison with my original idea for the extra buttons, an extra board that uses the empty slot next the spot for the remote board. It worked ok, but it required modifying an original one.
dirty PDBs fab'd them . 25$ shipped for 10 , not bad.
Here's the BOM with digikey part #s in case you wanna make you own. Attached is the cam bundle you'll need to order the PCBs.
button
PART: SW1177-ND MFG : Omron Electronics Inc-EMC Div / B3F-1060 DESC: SWITCH TACTILE SPST-NO 0.05A 24V
header
PART: 455-1628-ND MFG : JST Sales America Inc. / S5B-EH(LF)(SN) DESC: CONN HEADER EH SIDE 5POS 2.5MM
R41
PART: S1.2KQCT-ND MFG : Stackpole Electronics Inc. (VA) / CFM14JT1K20 DESC: RES 1.2K OHM 1/4W 5% CF MINI
Rx
PART: S3KQCT-NDMFG : Stackpole Electronics Inc. (VA) / CFM14JT3K00DESC: RES 3K OHM 1/4W 5% CF MINI
R42
PART: S18KQCT-NDMFG : Stackpole Electronics Inc. (VA) / CFM14JT18K0DESC: RES 18K OHM 1/4W 5% CF MINI
R43
PART: S39KQCT-NDMFG : Stackpole Electronics Inc. (VA) / CFM14JT39K0DESC: RES 39K OHM 1/4W 5% CF MINI
R36
PART: S56KQCT-NDMFG : Stackpole Electronics Inc. (VA) / CFM14JT56K0DESC: RES 56K OHM 1/4W 5% CF MINI
Enjoy !
- crank
  • tosh_remote_2018-09-15.zip
