Planeptsuntsun
Philippines
Hi everyone i have another system 246 with fate unlimited codes suddenly tye settings return to default i try to change the battery to a new one still nnot saving my settings what may be the problem ?
thank you very much
Did you get this issue solved? I'm having the exact same problem with one board in a twin Time Crisis 3. Reflowing the battery socket didn't work either and I tested voltages at the socket solder points. Both boards read 3v.
Thank you
Going to extend this a bit. Is it possible the OP was using a s246c motherboard because those and 256 contain an additional 5.5v .1f supercapacitor (exact same as Naomi) that isn't present in s246b and earlier. Both Time Crisis 3 board assemblies use s246c motherboards.
If leakage is a concern, then I should also remove the supercabs for both boards in a twin Time Crisis 4 as well.
