plasticfactory
That cp is sick! Really great choice of parts.
Heck yeah, hopefully you're happy with the results.The cable retainers were a bit of a mess after the cab was powder coated. They’d covered them with some sort of protective tape, but the plastic covering still melted. I picked and scraped all the gunk off and as suggested earlier in the thread I covered them with heat shrink. I was going to use braided heat shrink for a bit of a more premium feel but didn’t bother in the end as I had heaps of the normal stuff.
I found a couple of drips of power coat that had formed on the edge of the CP. I just scraped them off with a blade. It left the CP a little exposed, but for home use it’s not going to be an issue. I set up the control panel as well. Firstly sticking down the nice thick @alberto1225 overlay and then using a Dremel and router bit to cut out the holes. This removes the powder coat from the inner surface of the buttons, but to cut the holes using a separate bit of metal as a guide would have been a pain. I’m just going with four buttons for now as this will be a tate shmups machine. I found the 3D printed Buttercade bullet tops a bit sharp on the bottom with the joystick shaft length, so I’ve swapped them out with KDiT Kinu ball tops which match the grey bottom and Exceleena bezel better.
Thanks PASTBLASTER, they look and feel good to use.Beautiful work. I really like that matte balltop too!
Thanks, yeah the darks and brights mix came off well.That cp is sick! Really great choice of parts.
They’ll be fine hey. Once I wrap up the cables that’s how they’ll stay.Heck yeah, hopefully you're happy with the results.
Thanks hoagtech. It is nice to look at. Total cost was $850AUD. That’s not too bad considering they blasted the cab and over 20 parts and then primed them followed by the final powdercoat. Stripping and painting by myself would have been brutal.Your cab is coming along beautifully!
That powder coat is next level ..
No problem hatmoose. It feels a bit gnarly when one drives the bit through the plastic and when the bit hits the metal, but I just didn’t go too hard. Then I followed up with a softer dremel tool to get the last of the plastic ground away. I thought a lot about this and didn’t know what else to do. A blade wouldn’t work as the plastic is too thick and I was worried using a punch, step drill or hole saw would shatter the plastic. I also thought of running a cheap soldering iron around the edge but that could cause a raised lip.Thank you for this, I had always wondered how folks got such perfect button holes in the CPO without a punch, and now I know. Amazing job on the restoration! Keep up the good work
Yeah be carefulGreat work again
I've not seen those type of crimp connectors before, they look ideal for a scenario like that. What are they called? I'm a bit hesitant to google for anything to do with 'double enders' or 'two wires, one crimp'![]()
Nice find. Never seen those before.
Good work on the restore matey.
