There's two sets of wires, one pair each. One is an input, the other an output. You need to remove the transformer from in between and connect the input wires to the output wires.
raffy92,The supergun is working properly with an original jamma board. Where should I check for the continuity of button 1 and 2 ?
Not yet, I didn’t have time to focus on it.raffy92,
Did you fix the buttons issue? I have the same problem with my Sigma supergun when connected with mistercade as well.
What is the supergun sigma that you are using ?raffy92,
It's 1AV with 3TB fight stick.What is the supergun sigma that you are using ?
The last one I seeIt's 1AV with 3TB fight stick.
Has anybody put together a STL file for a case, for the remote V1 on the Mistercade? I'd buy the 'official' one, but the postage is nearly twice the price of the actual case - so not really practical.
I finally pulled the trigger with MiSTer and pre-ordered this for my Blast City!
I have always been that "real hardware only" guy but prices on PCB's are sky rocketing and I have had that De10 Nano on my closet for at least 2 years (got it cheap and un-opened) so I thought lets give it a change!
Hope that XL + Bottom plate fits with v1.2 too, just noticed that it does not list it as supported.
I'm planning to do "tate only" setup like in this video, hope I got everything needed for that. PS1 snac was just some extra if I want to do light gun stuff later on.
View: https://youtu.be/icRuUh8SIC0
Included with MiSTercade v1.1 Lite kit:
- MiSTercade JAMMA PCB
- MiSTercade Top Plate
- MiSTercade XL PCB
- MiSTercade Bottom Plate
- Mounting hardware
- 40 mm fan
- 20x20x10 mm heatsink
- USB bridge to connect to DE10-nano
Nice, you're going to love it! Double check to be sure; but I don't think the lite kit includes a top-plate which you'll need in order to connect the remote
@nassekova, looks like the lite kit does include a top:
And yes, the v1.2 will be compatible afaik.
I edited my post, but just in case you didn't see: it looks like the lite kit does include a top so you should be good. As well as an XL and Bottom Plate.Thanks! I will add that to my current order.
