corey
is that for sale
has the binary for that Atmel chip been dumped? I'm curious how difficult it would be to build a clone of this PCB... at least for the dips/JVS portas for the 2 chips on the board one is a RS485 to TTL converter the other is a microcontroller that takes in the TTL and spits out rs232 aswell as handle the dips and acts the the first JVS.
Btw, do you have pics and or parts numbers for the different models of this board?a very similar board is used in a TTX2 and they should be compatible with each other although i have not tested this yet. i will once a TTX+ arrives from japan in the coming weeks.
Haha, you found my ancient "omg how to bootleg TGM3" guide from when I knew next to nothing about JVS apart from the fact that it used RS485 as its transport protocol and the first RS232 to RS485 adapter that I bought happened to work with Type-X games by pure chance (I've tried the same with several PCI/PCI-e RS485 cards, but the initial handshake / control code translation causes the game to reject the connection).I came across this gallery that shows someone wiring a JVS serial interface to a rs485 adapter and using it directly. Has anyone here done the same?
http://imgur.com/a/grdqU
Picked one up from http://eshop.sintech.cnif compatibility is dependent on the adapter I managed to find that exact adapter on amazon: https://www.amazon.com/niceeshop-RS...=1507648166&sr=8-45&keywords=rs232+rs485&th=1
The MAX232 device is a dual driver/receiver that includes a capacitive voltage generator to supply TIA/EIA-232-F voltage levels from a single 5-V supply. Each receiver converts TIA/EIA-232-F inputs to 5-V TTL/CMOS levels. These receivers have a typical threshold of 1.3 V, a typical hysteresis of 0.5V, and can accept ±30-V inputs. Each driver converts TTL/CMOS input levels into TIA/EIA-232-F levels.
Related:The MAX481, MAX483, MAX485, MAX487–MAX491, andMAX1487 are low-power transceivers for RS-485 and RS-422 communication.
