beharius
Istanbul
Hayabusa is our latest addition to our supergun series. It's based on our highly popular Shogun Ultra supergun. Now You can enjoy your games your with your favorite Playstation(1/2) compatible controllers or arcade sticks as it has 2x Playstation(1/2) controller ports instead of regular Neo Geo controller ports(DB15). It can be used with commonly found JAMMA based arcade boards and Chinese boards.
- Impedance matching, amplified RGB video output by using the renowned THS7374 video amplifier chip...
- Individual potentiometers for calibrating the RGB color levels
- Includes a low-pass filter that can be enabled or disabled.
- Euro Scart connector for audio/video output.
- Kick Harness connector
- Dipswitch for enabling the Buttons 4,5 and 6 from the Jamma or Kick Harness.
- 2 types of Sync mode is selectable with a jumper: attenuated and buffered by THS7374 or Scmitt trigger
- Built-in audio attenuator.
- Line level audio input from terminal jack or 3.5mm Headphone jack
- Stereo audio output, selectable audio source, attenuated MVS or Line In
- MVS/Mono switch
- 2x Playstation (1/2) controller ports with all 6 buttons wired (can be used with CPS, Atomiswave and Chamma boards like Pandora).
- Button remap feature
- LCD Voltmeter for the 5v input.
- Test, Service and Coin1 push-buttons.
- Blue power led.
- OSSC safe.
Package includes
1. a high quality custom power cable with 6 pin Mini Fit Jr. connector (2xGND, 2x5V, 1x12v, 1x-5V)
2. a custom made Kick Harness for the CPS2/CPS3 boards.
3. a custom designed, smoked transparent, 3mm, laser etched, plexiglass shell.
Available in August/September '22
Nice, loving the innovation, especially right at the moment when it is so hard to bring products to market with the whole component shortage thing going on. Good luck with the product, I hope it sells well.
