Anyone here able to get their Playstation 4, Brook UFB, P-ras 3 cabinet, and @Lemony Vengeance harness working together? I'm having issued and I'm certain there's a configuration or setting I'm getting wrong.
The Pras-3 cab is working. Windows 10 recognizes the Sega IO in the backmof the cab, all the stick directions and buttons are registering in the Windows USB controller setup application, and the controls work as expected with my controller configuration in Steam. However, when I plug the new harness into the control panel, I encounter issues. Now, only a few buttons are registering in the Windows USB controller setup application.
The Brook UFB is working. When it's connected in a fight stick setup, the stick and all the buttons work on the Playstation 4. However, when I install the Brook UFB to the the harness installed on the P-ras 3 cab, issues crop up. The Home button, X button (1K), and O button (2K) work as expected. I can get the PS4 to recognize the setup as a controller. However, the stick directions are not registering, so I can't navigate the PS4 UI. The other buttons don't appear to work either.
I'll try a few more things to troubleshoot:
Un-plug then re-plug connectors.
Test with the Sega IO board in the back of the cab powered off.
Test continuity on the wiring harness.
Let me know if you have any suggestions.
I'll attach a photo or two shortly.
Here's a snapshot of the setup:
