DARKSOFT Darksoft's MultiMVS Latest Firmware, Menu and Instructions
Since the last firmware / menu update I was having issues with KOF 98.
There was no way to boot it, I was stuck each time on the red warning screen (with unibios / or stock bios).
@Darksoft explained to me that it was a battery issue and that "some games check that it's working properly as a security measure to make sure you are not playing in AES for example".
I could have realized there was a battery issue by myself, because when cold booting, the message "Restoring to defaults" was always displayed.
I've now tried another slot, and tada, no more issue :)
Hope it can help.
A power failure occurred while updating the firmware. The motherboard no longer recognizes the cartridge. Can it be initialized? help me.
電源サージのために壊れていない場合。 おそらくファームウェアファイルをmicrosdの/ updateフォルダにコピーするだけで復元できます
I am sorry that I do not understand how to reply.I tried the update again, but it did not become the initialization screen. It is a cross hatch when the motherboard does not recognize it.This time I bought two, but one got in this state.Do you have repair support?
Hello,
Newbie here!
I recently received by MultiCart, but have only just got round to setting it up and I am having some issues.......
I get the green screen, then it says something like ‘checking file system’ then it says something like ‘restoring to defaults’ and then just a blank screen.
To be honest, I am not sure the files are all correct in my microSD. They are:
Games/menu
Update/menu
In games I have the game files from the rollup pack and menu files from the download (in a menu subfolder).
Update/menu - This also contains the same files (latest download), I also put the Flash file and an ‘up’ file in here - Is this correct, as a I wasn’t sure where the flash folder went?
Anything else I am missing?
Any help, as I am desperate to get this up and running.
Cheers!
How long are you waiting?
The first time can take a while.
I am leaving it about 5 minutes, then I switched it off. Too soon maybe?
Do my file paths look corrrect? This is a brand new microSD, so no old files obviously.
Hello,
Newbie here!
Games/menu
Update/menu
Cheers!
Dir structure looks right. You dont need an Update folder if you don't want to update, though.
My first suggestion would be to try another SD card.
5 Minutes is enough time in any case. I dont think I waited more than 2 minutes with mine.
Thanks. It is the Kingston one that came with the cart though, so I assume that would be OK?
What is an “up” file? Also just checking if you’re using a PC
Sorry, yes I meant 'Top' file.
Yes, using a PC to format the card and transfer the files etc.
#1 removed SD card
#2 cleared NVRAM
#3 deleted BUFF file on the SD card
#4 copied flash.img file to update folder of the SD card
#5 put SD card back into the MVS, powered MVS on and waited until the update was finished
#6 removed SD card
#7 cleared NVRAM
#8 deleted BUFF file on the SD card
#9 copied top file to update folder of the SD card
#10 put SD card back into the MVS, powered MVS on and waited until the update was finished
#11 removed SD card
#12 cleared NVRAM
#13 deleted BUFF file on the SD card
#14 copied menu folder with files to update folder of the SD card
#15 put SD card back into the MVS, powered MVS on and waited until the update was finished
#16 power cycling - done
have you tried to do each one separately or all at the same time ? please follow SVM's post
Thanks for the replies everyone!
I managed to get some help from a mate who has one and he sorted it for me. I think the issue was that was trying to update straight off the bat, rather than setting it up first.
Anyway, we are up and running!
You are most welcome :) Learnt it all from the guys on this forum, good to share the knowledge! If you go back a fair few pages on this thread I was stuck for a while too so totally know what it’s like! The cart is amazing once it’s all up and running, love it
