SVM
- Joined
- Aug 30, 2016
- Messages
- 180
- Reaction score
- 153
Could be possible...That must be a bug in the UNIBIOS.
Little bit off topic, but I think, I've discovered another bug in the Unibios: MVS stereo mod & Unibios (3.2)
That's the plan...Seems like it would be a good if the cart just made the UNIBIOS a thing of the past and gave you the same functionality with a stock bios. Or make a custom BIOS that doesn't have any of the redundant code for use with this bios. (No idea how hard that is, probably a lot harder and more trouble than its worth)
The amateurs players use the cheat functionality a lot.Anything other that the Unibios adds? Never used it myself, stock BIOS FTW
Single coin slot/shoot on MVS (arcade) USA (region)!Anything other that the Unibios adds?
Yes I agree, the time has come for stock BIOS to return and multicart can set the region (just don't forget that hack above).That's the plan...
I use it to pause the game the most.The amateurs players use the cheat functionality a lot.Anything other that the Unibios adds? Never used it myself, stock BIOS FTW
Pausing is cool. But...dont use it, takes away form the arcade feeling. You gotta finish the game in one go, put all your quarters inI use it to pause the game the most.The amateurs players use the cheat functionality a lot.Anything other that the Unibios adds? Never used it myself, stock BIOS FTW
I'm using the multicart on my Analogue CMVS Slim without any errors at all since day 1 (except i was too impatient and forgot to copy the menu folder). Since then everything has been working 100%.For Omega & Analogue CMVS users we won't buy a stock bios to replace our UniBios.
what's not supported?I just need to know if we can wait for theses consoles to be fully supported.
The Analogue and Omega CMVS's come with the UniBIOS. And anyone who bought them for the simplicity of needing to do nothing and have it "just work" may take issue with:what's not supported?I just need to know if we can wait for theses consoles to be fully supported.
I'm pretty sure that's what Tgames was referring to.That's the plan...Seems like it would be a good if the cart just made the UNIBIOS a thing of the past and gave you the same functionality with a stock bios. Or make a custom BIOS that doesn't have any of the redundant code for use with this bios. (No idea how hard that is, probably a lot harder and more trouble than its worth)
We never said that it won't be supported. It rather wont be needed as it won't add anything new to what you currently have. We plan and we'll do our best to make all motherboards work with all BIOS, original and UNIBIOS. UNIBIOS add some delays and interferes with the original working of the NeoGeo (as compared to stock BIOS) so it may be a bit of an issue with 4 slots and 6 slots, but for the rest I believe it won't be a problem.I'm using the multicart on my Analogue CMVS Slim without any errors at all since day 1 (except i was too impatient and forgot to copy the menu folder). Since then everything has been working 100%.For Omega & Analogue CMVS users we won't buy a stock bios to replace our UniBios.
If with future updates the Unibios won't be supported anymore, i would be very disappointed.
First of all. Did you try the multiMVS as you received it, before trying to updae? Everything was OK?Hi,
i get my multi MVS today, try it on my CMVS omega, load my 16g sandisk fat32 with roll up pack, get the "menu" update, place the last "menu" folder in "update" and the files in "games" /"Menu" i do this 3 times but no menu on the screen, just black screen, nothing happens, i did something wrong ?
No mac.Sorry if this has been explained earlier but do I need to format this memory card on a PC? Would it work using a mac?
