Megalocade
Uk
Hi folks
I've just got hold of a genuine set of super street fighter 2 new challengers rom set, includes mask roms, pal and daughter board and I want to put this on an a spare doner board which was Xmen Vs street fighter rev 7 board, all the roms are in and I set the jumpers taken from a list of jumpers for all the cps2 boards but when I fire this up I have black vertical bars going through the screen and the text like is all messed up, I've tested all the roms and they all verified ok, I'm at a loss as to where to go next I'm convinced this is a jumper issue but I've gone over it several times and they are correct I've even run a multi meter arcose them to make sure they test ok.
SOOS_SO_OSSOSO_OSOSOSOS_OSOSOSOS
Both A and B boards were working fine before the conversion, I've even put the xmen roms back in just to see if I've inadvertently messed up the boards but no that game displays just fine, I know SSF2 came out on early revision board is there a difference between early revisions to rev 7 boards.
The cps2 conversion page has dead links I needed to see jumper settings page where is showed how the jumpers work, so you can set from eproms to mask roms.
Bump because same issue, though less pressing for me.
There is no current jumper list on the net that hasnt been taken down I can find.
I uploaded it here https://mega.nz/file/AYdRhBIb#U8Hbia_VgzQggUPcBBQB1naoqJidtnfTFbwxP4YDp0E
According to the spreadsheet Xmen Vs SF should be SOOS_SO_OSSOSO_SOSOSOSO_SOSOSOSO on PAL F
Ok finally found the problem wrong pal even though is says BGSB3, I thought ok I'll burn another of those encase it was messed up but still the same problem this threw me as SSF2 calls for a BGSB3 pal.
I decided to burn a BGSB3B pal as that's what's in my SSF2X and result! The jail bars gone and all working
