I know mate. But it's all come at once I'm not made of money. I'd also struggle to fit them in a woody JAMMA cab but have some plans for that in the works.Hold off too long and you might just end up with nothing.
Just put my order in for a panel and 2 spinners. I hope to grab two more spinners but that wouldn't be likely until late next month. If I do end up going for 2 more, would combine shipping at all be possible or how does that work?
Thanks for your order, and i think we can manage something about it
Thanks.
I've just put an order in for another two, hope this helps push this to the finish line.
I may be interested in buying a second setup with 2 spinners but it wouldn’t be until end of March
I might just have to join the party having read thisSmall update on the Mister support side:
Decided to go with this design, so it adds joystick, buttons and spinner support
So this should make it easier to make your own controllers/panels, etc.. for use with mister, etc.
Also, dont sleep on placing your orders for the spinners, you can split up your payments if you need to.
If you were serious, that's a very kind offer chap. Thank you very much. I have however just placed an order for two of them myself.want me to order two for you? I just keep them if you dont want them..
I wouldnt say if i wasnt serious.If you were serious, that's a very kind offer chap. Thank you very much. I have however just placed an order for two of them myself.
Overall height of the Sega Saturn stick HSS-0130 is 70mm so don’t think it will work.I appreciate that @Mirko . Mine is in storage at the moment and probably not in front of me until after this (hopefully!) ships.
If you happen to have rotary sticks, you will be able to connect those alsoI might just have to join the party having read this
Yeah, it’s too bad. The main problem with the HSS-0130 is there is a compartmentalized controls area that is enclosed from the bottom and takes up some of that precious space.Much appreciated - thanks for checking this! Guess I'll find another use for this case.
