Sega Blast Cities
What JVS I/O are you using? Do you have the analog section of the I/O connected to anything? (On a Sega JVS I/O this is the medium sized 26 pin black connector.)
Sega Blast Cities
Signal | Sega JVS I/O CN6 Black 26 Pin JST RA | Blast City Cabinet I/O Output CN8 White 8 Pin JST NH | Blast City Cabinet I/O Input CN10 Black 60 Pin JST RA | Blast City Control Panel Amp UP 10 Pin | Analog Joystick |
Analog 0 (P1 Vertical) | 3 | 1 | ? | 1 | P1 White |
Analog 4 (P2 Vertical) | 4 | 2 | ? | 5 | P2 White |
Analog 1 (P1 Horizontal) | 9 | 3 | ? | 2 | P1 Red |
Analog 5 (P2 Horizontal) | 10 | 4 | ? | 6 | P2 Red |
Analog 2 | 15 | 5 | ? | 3 | |
Analog 6 | 16 | 6 | ? | 7 | |
Analog 3 | 21 | 7 | ? | 4 | |
Analog 7 | 22 | 8 | ? | 8 | |
Analog Vcc | x* | x* | ? | 9 | P1 + P2 Yellow |
Analog Gnd | x* | x* | ? | 10 | P1 + P2 Black |
Wow, I'm a bit more lost than I thought. I didn't think I need an i/o for this. I thought it was plug and play to the jamma edge.What JVS I/O are you using? Do you have the analog section of the I/O connected to anything? (On a Sega JVS I/O this is the medium sized 26 pin black connector.)
Have you never used a Naomi before?Wow, I'm a bit more lost than I thought. I didn't think I need an i/o for this. I thought it was plug and play to the jamma edge.
Which sega jvs i/o do you recommend?838-13683-02 rev. A?
Ofcourse I have, I just currently have capcom i/os. I gave away my sega i/os so I'll be buying one of those again. I may have that Blast harness somewhere as I've upgraded to the -001 loom. I'm just legit not well versed in jvs stuff.Have you never used a Naomi before?
The -001 cn5 26 pin header is too big to fit onto the jvs io and Capcom io. What am I doing wrong?
This makes so much for sense. Thanks dudeThis is a Sega IO, I believe the Capcom IO has the same connector:
This is what the harness looks like in a Naomi cabinet. It has individual P1 and P2 connections but then most panels use an adapter back to the 10 pin connector:
This is the Blast City analog loom:
It connects to the Blast City cabinet IO board, CN8:
And then analog controls are on the 10 pin connector under the control panel:
You da man Lem!I’ve made one of these for myself and my future monkeyball setup.
I’ll hook ya up.
Yeah, it's part number 600-7143-004, I actually found one on ebay easily. It has the CN8 connector for Blast cities as well as 10 pin connectors for Astros and Megalos.I didn't realise there was an official harness for analog to CN8 to use on the 10 way connector
Funnily enough, there was a time @Lemony Vengeance and I were talking about using CN8 as a pass through for Monkey Ball which I'm still yet to do - I just pass through my cable in that empty socket on the blast panel
