Did you mean "without?"
Is the best way to do an arcade CRT to use the 240TS? I was thinking of using a NEOGEO flashcard with that loaded, but won't that just set it for that PCB and each other PCB will look slightly different?
I’d forgotten that the 240P Test Suite is available on Neo Geo now. That’s definitely a good choice for an arcade PCB you can use for a calibration pattern generator. I’ll update my earlier post to
@Crunch to mention it.
As far as each PCB looking different from the Neo Geo, well that would happen anyway even if you calibrated with a professional pattern generator - arcade boards weren’t consistent with each other even back when they were brand new. That’s why it’s a given that you’ll have to readjust the CRT H-Size, V-Size, Brightness, etc when you swap boards.
This can be an in-depth topic, but as I see it, there are two approaches to calibration for a CRT candy enthusiast:
- Calibrate so the CRT looks good, displays a full range of color, and looks as identical as possible to my other CRT candy cabs.
- Calibrate the CRT to the most accurate industry reference possible.
You can achieve the former by using the same 240P Test Suite across all your displays, ie pick one Neo Geo board or MiSTercade and always use that one for calibration. Your results won’t be industry professional spec, but the colors will look good and your cabs will look similar to each other.
For the latter, you need to use a pattern generator that has been specifically tuned and tested to meet the industry specification for accuracy. At the enthusiast level, the pattern generators I know where I know that’s been done are:
PGenerator for Raspberry Pi
- MiSTer running
HCFR
- Sony BDP-S350 Blu-Ray player with
FreeCalRec601 discs
