@chrischunli @remnant42 - thanks for the interest
This has ended up being a bit of a development thread so I thought I would keep this information here...
I initially designed the kits to fit my Vewlix Dia Blues but as it looks like others may want the kits I've been able to check and refine the design with the help with a couple of friends (I'm looking at you
@wonderbanana and
@wigsplitta ![love :love: :love:](/styles/default/xenforo/smilies/bb/love.png)
Whilst I was test fitting a kit on
@wonderbanana 's Vewlix F I measured up for the corner brackets. Nothing super exciting but this is the L bracket in CAD:
Sent over to my man
@Ordyne and precision cut/bent:
@wigsplitta very kindly offered to help test a kit of both of his Vewlix C and AMI L so I stripped one of my kits from my Dia Blues and sent over to him.
Corner brackets fitted:
One monitor kit fitted to Vewlix C:
Also fitted to his AMI L:
The monitor he was fitting to his AMI L has a 'VESA' spacing of 200x100 which was also offset/located at the bottom of the monitor.. My original mount (selfishly) only supported 100x100 and would not fit his monitor. He managed to get it to fit with some Mc'Guy'vering but I want to make this as universal/future proof as possible for everyone.
This is my current plan for the VESA mount:
This should fit any monitors with 75x75mm of 100x100mm 'central' spacing (including cut out for LG stands) as well as 200x100, 100x100. 75x75mm offset spacing where the mount points are at the bottom of the monitor.. 50x50mm is also an VESA mounting pitch but I can't see that being used on a 32" monitor so I've omitted it unless anyone thinks it's worth adding.
It's hard to test/cater for every cab/monitor combo at this point but with the work done so far I think we're in a good position to start an initial interest thread. I'll link back here once I've started one.
Thanks all for following and for your input. If you have anything to add then please go for it.
