DeltaWaldo
Baltimore, MD
Hello all,
I am having trouble with a Streetfighter 2 bootleg I just got. When I was inspecting, one of the regulators fell off. Can't find it but I think on the board it says 'T518'. I replaced with a T518B from ebay. When I hit the service button on the super gun I get a chime so I think everything is working? Please confirm that it's the proper chip. (Pictures show the PCB+supergun and zoomed in on the chip that was changed out, part of the silkscreen has been rubbed off). I think it's a mstreet variation, does anyone know if I have the right chip? Also thinking I might need to add more solder to the super gun port.
Also noticed these chips are damaged should I replace?
Thanks, definitely got that one and was able to trace it so that can't be it. So funny thing, back when I first plugged in my Power Supply I had it set to 220 but with standard 110 supply. Did I burn out my board and supergun? I did switch the supply over to the correct voltage. The 12v rail is running a bit high (13v)
