Orakelschaf
Hello,
i hope someone here can point me in the right direction with the (right channel) audio problem of my sega naomi 2:
Problem
Things i tried so far
NEC C844G (IC39)
I replaced and measured the NEC 844G (IC39):
Thanks alot!
Problem
- within the test menu -> sound tests i turn left and right speaker to ON
- left speaker outputs sound
- right speaker does NOT output sound (the problem!)
- video and gaming works 100% perfect, but right audio channel is missing
- Checked if there is a jumper or setup config for mono/stereo stereo. Have found none.
- Checked jumper setting with another working noami2: matches
- Replaced Filter board: No change. It is not the filter board.
- Checked cables: It is not the cables.
- Power supply provides enough voltage.
- Replaced IC 39. No change
- Complete recap if the board and the filter board.
- Visuell Inspection of blown parts/missing traces : None
NEC C844G (IC39)
- Pin 01 (Out1): 5V - Shows Sinus wave if left channel is active
- Pin 02 (Ii1): 2.6V
- Pin 03 (IN1): 5V
- Pin 04 (V+): 12.2V
- Pin 05 (IN2): 5V
- Pin 06 (Ii2): 2.6V
- Pin 07 (Out2): 5V - Does NOT show sinus wave if right channel is active
- Pin 14 (Out4): 5V - Does NOT show sinus wave if right channel is active
- Pin 13 (Ii4): 5V (shouldn't this be 2.6V? maybe there is an issue?)
- Pin 12 (Ii4): 5V
- Pin 11 (V-): 0V
- Pin 10 (IN3): 5V
- Pin 09 (Ii3): 2.6V
- Pin 08 (Out3): 5V - Shows sinus wave if left channel is active
Thanks alot!
