nnap
question to the experts. Would it be possible to match a Sanwa 29E31S Chassis with a Nanao MS2930 tube if I use the convergence ring and yoke from the Sanwa?
Yes, because the neck connectors are the same.Would it be possible to match a Sanwa 29E31S Chassis with a Nanao MS2930 tube if I use the convergence ring and yoke from the Sanwa?
Same neck connector. The tube has a different curvature though, so with the wrong chassis is might look off in the corners.I was under the impression that a 2932 has a different neck connector then a 30,31, and 34. Am I wrong here?
Do you have pics of this by chance? I've never heard of this and it doesn't make sense to me. Tube will have to follow standard pinout especially on exact same model. Your claim is: company making the tube decide part way through manufacturing to rearrange neck pinout to accommodate one of many completely different non related 3rd party chassis manufacture? Seems not accurate no?Yes, but sometimes you can run into issues with tube number/connector type. The tube used with the 2932 is the same tube used in I believe a NAC, but the connector on the neck is totally different.
What I'm saying is that a 2932 chassis from certain Naomi setups comes with a a68kju96x and @djsheep said that tube is in both of his Astros. If the same tube is in both cabs and they use different chassis, they must have a different pin layout no? If they had the same pins on the neck everyone would be converting NUCs over to 15k using Astro ms9s.Do you have pics of this by chance? I've never heard of this and it doesn't make sense to me. Tube will have to follow standard pinout especially on exact same model. Your claim is: company making the tube decide part way through manufacturing to rearrange neck pinout to accommodate one of many completely different non related 3rd party chassis manufacture? Seems not accurate no?Yes, but sometimes you can run into issues with tube number/connector type. The tube used with the 2932 is the same tube used in I believe a NAC, but the connector on the neck is totally different.
Funny story, a similar thing happened to me. I had a perfectly working, nice looking MS2930. I bought a replacement MS2931 chassis from Yaton. I thought I might as well test the thing. I connected the chassis to the tube, double checked everything, turned it on and saw a spark near the yoke, inside the tube. Turned it off instantly. Didn't think much of it, thought that the chassis is faulty. Connected the original working chassis back, turned it on, and surprise, no picture. There's some sparking in the neck. Connected the tube to a B+K CRT analyzer. Analyzer gives absolutely zero readings on the guns.I have this Nanao 2930 Tube with a 2930 chassis. Somehow there was a grounding issue and I got some high voltage arching in the neckboard area. After that the monitor was dead, no neckglow, nothing. Then I got a 2931 chassis but I am not sure if it works. There I get little sparcs in the tube and possibly the yoke. So I don't know if the tube is toast or just the chassis or even the yoke.
